Thread: IC Coolant Tank
Old May 6, 2011 | 01:49 PM
  #42 (permalink)
Sheldon's Avatar
Sheldon
Default Re: IC Coolant Tank
Is there much of a difference in going the new tank route over using the needswings coolant separation kit?
I know Rob says the temps should never get high enough or build up enough pressure to need another tank? Is this still true if you use an ASP 178 pulley or similar?
