Originally Posted by Sheldon
Is there much of a difference in going the new tank route over using the needswings coolant separation kit?
I know Rob says the temps should never get high enough or build up enough pressure to need another tank? Is this still true if you use an ASP 178 pulley or similar?
Yeah, I saw that kit. It would be easy enough to try, but I'd like to have the tank just in case.
If in fact the inter cooler coolant temperatures never get above boiling then the expansion pressure would do nearly nothing. But if you close those valves while the system is at running temperature. Then you create a mild vacuum when the fluid is cold and mild pressure when the fluid gets above normal operating temperature.
That's why I would prefer to have a small tank with a reserve and air space for expansion. I'll put a pressure cap on mine, probably only 7lbs.
I'll be back to post pictures and results for sure when all is said an done, but it may be a week or so.
