Old May 6, 2011 | 09:51 PM
green-ghost's Avatar
green-ghost
Default Re: key in ing chime and door lock questions
Originally Posted by mferreira3417
when you put your door panel back on all will work ok the little screw on the cover by the door latch that is attached to the door actuates the door ajar switch. of corse the bcm takes a while to recognise the door is open and turns on the dome lite open and close the door a few times after you put door panel back on and you will be fine
haha...thanks, I just finally got my butt off the couch and found the door agar switch...How did I ever miss that thing?! you are right, with the door panel pulled off the switch isnt getting pressed in all the way. I held it in and the dome light faded. Problem solved!!!!
