Re: Homelink on the Crossfire..?
If you follow the instructions in the manual you should have no problem. Some openers like ours here in Canada operate on a"'rolling code" and you would follow a different Homelink programming procedure than those in the U.S. but this procedure is covered in the Owners manual.
You just need to find out if your door opener receives a "rolling code" and proceed from there.
Good luck.
