Re: key in ing chime and door lock questions
Originally Posted by mferreira3417
when you put your door panel back on all will work ok the little screw on the cover by the door latch that is attached to the door actuates the door ajar switch.
of corse the bcm takes a while to recognise the door is open and turns on the dome lite open and close the door a few times after you put door panel back on and you will be fine. with out the little screw in, the bcm (body control module ) does not know the door is open and so it does not turn on dome lite
It is the molding around the latch on the door that operates the door ajar switch by pushing it in, not a screw.
With this molding off, as when the door panel is removed, the switch is not activated, the interior lights will switch off when the timing for them activates to save the battery.
Green-ghost, do you have the same layout as shown in my photo, or are more or less wires visible?
