headlight adjustment
May 7, 2011 | 09:22 AM
permalink
onehundred80
Apr 2006
25,432
651
Ontario
Re: headlight adjustment
Quote:
gtrguy
What is the easiest way to aim headlights. I found the large white-capped horizontal adjustment screw, but where is the the vertical adjustment located. I have looked for the leveling bubbles but cant find them.
Any help would be appreciated.
Thanks
If you have just changed a bulb and the lights are not aimed properly and they were fine before the change, then you have put the bulb(s) in wrong. The units only use the the one screw as the projectors are preset in the units. There should be no reason to change the adjustment normally. No bubbles are on these units.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
