Originally Posted by velociabstract
You want to try to move weight to the rear. So lower the pressure in the rear and raise the pressure in the front. Or better yet, change out the spring pads in the rear for the thinnest. It will help some but don't expect a miracle.
Les
Weight to the rear would. That's why you STIFFEN the rear. During a turn weight shifts to the outside wheels. More weight will be on the stiffer end.
