Thread: Tire pressures
Old May 7, 2011 | 05:22 PM
Spudracer's Avatar
Spudracer
Default Re: Tire pressures
Originally Posted by shortfellow
Mine is the bassic CF. 2004. The rear tires are the stock Contis. I just replaced the fronts with the very sticky Dunlop Z1 starspeck. Please, no sermons on different front and rears. I bought the new stickies, of course, to reduce understeer. I'm sure it will, but if it still understeers excessively I can experiment with F@R pressures and the camber bolts(which I have).
I was affraid of getting conflicting views on the pressures but it was worth a try. Thanks for the replies.
Yeah, well here comes the sermon. The Star Specs are an excellent tire. I had a set on my S2000 for a year and loved them on dry roads and in the rain. But, you've just mixed a very sticky extreme performance tire with a long wearing set of all season Conti's that are 6 years old. Nothing good will come of this. Why are you farting around with tire pressure and mixing tires? Why not just put a proper set of tires on the thing and then work through suspension setup until you dial in the behavior you want?
