Re: I need a step by step zietronix how to
your right on the money les. the bcm is a pain to get the wires out. per rudy strip the coating and solder it in then tape it up. the ecu pins can be removed and heat shrink used.
a arm bushings the same. r170 i actually have a set from my old 32 that i never installed. guess ill save them for the new 32 when it needs them.
did you drill the y pipe for a sensor for boost? woody has an interesting post about false boost readings due to perssure and the difference from the manis to the y pipe. same can be said for the fuel pressure reading at the end of the rail. glad to see your able to data log now!
