Originally Posted by velociabstract
I purchased the A-arm bushings today at the local Mercedes stealership. Ouch! The instal will be satur..... I'd better call the shop. I've been data logging for a while but without the AFR's. I wish I had logged the AFR's pre tune to know what's was normal. What I'm seeing has me -------- in my pants! I'm breaking out the depends! I emailed Jerry today and he recommended a change. I'm waiting to see when we can schedule a retune.
I only soldered the wires necessary for the AFR's. The EGT's and boost are a future project. I read boost with the dashdaq from the OBDII port. (17 lbs. max with a Code3)
All you owners out there that think you want a tune in the future. Get a wide bank installed now! That way you have experience and knowledge pre tune. You'll sleep better.
Les
that's my biggest fear Les...got to get the rearend done first...then off to see Rob...for a Zeitronics...
