Old Sep 7, 2005 | 04:22 PM
juddz's Avatar
juddz
Default Re: Time to put in the subwoofer...please share your expertise!
Thanks for the info. Any idea what color the remote wire is? And, any idea what colors are used for the speaker wires? I have to tap into them, for an amp signal (as I assume the stock deck does not have any RCA outputs).
BTW, I figure I won't have to bolt down the masonite sheet, as the mass of the subwoofer and the perfect fit of the panel ought to keep it from going anywhere. And, I figure a 1/4" thick masonite panel with holes drilled through it will not add more than a few pounds. to the car, esp. if the stock cover is removed and stored away.
