Old May 11, 2011 | 09:09 PM
kolevski's Avatar
kolevski
Default Re: UPDATE!!! Twincharged crossfire numbers
Congrats on the numbers!
Can you create more boost without making the supercharger spin faster? e.g. what Eric is doing, having a twin turbo blow air into the supercharger.
Opposed to getting larger crank pullies to make the supercharger spin faster to create more boost?
The reason I ask this is because if the boost created by the turbo makes the supercharger spin faster just like a crank pulley would it's pointless on 2 levels.
1. It will end up destroying the supercharger as I believe its limited to somewhere between 17,000 - 18,000 RPMS. Any faster and it will literally melt.
2. If you really wanted to toast the charger you could get a 200mm crank pulley and run a Code 3 or something similar and make 30+ psi boost.
However if Eric's method doesnt make the supercharger spin faster and still increased boost then its a fantastic mod.
I'm not sure of the technical aspect so just putting it out there.
