Re: Mandrus Milleniums !!!
Dave, my guess is the 20x11 will look MEAN.
I am not sure since I have not run anything THAT wide, but hopefully someone can comment.
If the wheels have a 30 or 32 offset and the OEM wheels have a 22 offset (the limited wheels do, not 100% on the SRT, thought it was the same) you are going to need a spacer to 'push' the wheels out farther, or they will be an additional 8-10mm INSIDE the wheel well, not sticking out, and that is your problem. Measure the room between your OEM wheels and any other components in thw wheel well to see if the additional inch or two will kill you, I think with spacers you will be fine, and have the look you want.
Remember to measure your rear lug bolts to make sure they are not too long or they will destroy your Ebrake capabilities....
