Old May 12, 2011 | 03:54 PM
Airscape's Avatar
Airscape
Default Re: Crossfire console
Did you get this sorted out? Found everything I needed using search but basics from memory.
Lift silver plastic around shifter, unscrew 2 screws holding front and rear console together pull up bottom liner in rear bin, unbolt, get some hot water to help lube the Ebrake rubber handle, pull that off. Lift entire console up slowly, disconnect any wires (extra stuff for roadster as explained in above linked post)
There is a thread that has a few pictures from a couple years back. If you still have troubles or can't find it let me know.
