Thanx for the quick reply Tpulling! That is the strangest fix, considering the original symptoms!
By 3 mounts, it sounds as if you are referring to the two motor mounts that go on the left and right side, as well as the center transmission mount?
I would prefer to change the mounts, as it's easier than changing the clutch system, but it still boggles me how this would keep you from changing the gears due to a very stiff clutch pedal?
I started a new post for mine:
Can't shift gears while driving anymore?
