Re: IAT sensor & Boost bung install - Tutorial
I installed a needswings teflon coated 'Y' without removing the plenums, as usually removing the plenums means new gaskets. After removing the hose clamps you just need to 'unstick' the rubber from the aluminim by sliding something like a feeler gauge around the circumference of the pipe. A little WD40 made it easier to re-install
