Old May 13, 2011 | 12:28 PM
  #67 (permalink)
NattySway's Avatar
NattySway
Default Re: LED running lights (Audi replicas)
You put headlights that cost over $500 a piece in the oven? If you would have read the NUMEROUS threads here with others that have tried this, you would know its not possible. Not trying to be a 'told you so', but saying that searching is easy and saves lots of time and money. With the age of the car, there is very little someone has not tried. In a 5 second search I came up with this:
Credit where it is due to Nox1s
"I wish I could say I did something fancy, extravagent, and hard, but I didn't. It's really easy.
I bought two 19inch LED strips, the ones encased in silicon, white in color (Flexible LED Strips)
Excuse me, but I did search for it. As a matter of fact not only did I search this site but others as well. There's people who have done it. For me it was just becoming a hassle and I chose to stop before I did more damage then good. That search you sent me I read already but I didn't want to mount them on the outside for fear that they look cheap. So don't worry about being a "I told you so kinda guy."
I had to cut about an inch and a half off of each one, because it went up to high and I didn't like the look and they kinda didn't fit.
What I did to mount them since it was so cold out is kinda just brute force.. there is enough room to shove them in between the gaps of the lights.. and on the sides where it's REALLY tight you can use a razor blade or file to shave some silicon off (won't hurt the light at all).. then proceed to shove in the space again..
Wiring them was also easy as well, I used T-Tap connectors to tap into the existing parking light wires, so that way I can control them from the interior cabin. I originally bought a switch to wire inside my car but I think this way is easier and looks a lot cleaner, they now come on whenever I turn on the parking lights and stay on for another ~10 seconds when I lock the car / shut it off / shut the door and exit, until all the lights turn off, looks really cool."
Hope this helps
Excuse me, but I did search. As a matter of fact, not only did I search the xfire forum but other sites such as YouTube as well. There are people who have done it. For me it was just becoming to much of a hassle and I felt I was about to do more damage then good. And that search you sent me I already read. I just decided not to mount them on the outside for fear of it looking cheap. So now you don't have to worry about being a, "I told you so kinda guy."
