Old May 14, 2011 | 11:15 AM
NeedsWings's Avatar
NeedsWings
Default Re: Any DIY Supercharger / Intercooler removals?
here is the pictures from when i removed our intercooler as it was leaking and needed to be replaced...
Login
remove air intake
remove intake plenums
remove throttle body
remove vacuum lines
remove lower ypipe
remove fuel rail
remove IC coolant line connections
remove belt
remove bolts holding down supercharger
remove supercharger/intercooler assembly
you will need new
lower intake manifold gaskets
upper intake manifold gaskets
sc to ic gasket
benz sealant
