Old May 14, 2011 | 08:47 PM
RaulRocks2's Avatar
RaulRocks2
Default Question about Code P0341
Hello everyone. I got a CEL on last Saturday. I didn't notice anything different with the car, it was running just fine, but took it to Autozone to get the code and it gave me the P0341 camshaft position sensor. That night when I got home I check the sensor moved the cables around there a little (btw I barely touche the sensor and the clip that holds the cable in place snapped, but it still holds itself in place) and when I started the engine again the CEL was gone. It didn't come on until today, I didn't pull the code but I'm sure its the same cause the car was running fine still. The only difference I noticed, and it may just be my imagination, but I think the car revs higher. My question is, should I go right into changing the sensor? I found some on autozone and such websites but the pictures online show different looking sensors so I don't know for sure which one I need.
will this fit->Your Parts Search Returned 1 Part(s)
it says it's for a 2004 slk320 but it looks just like the one on autozone here ->Duralast/Camshaft Interrupter-Magnet (SU6900) | 2004 Chrysler Crossfire 6 Cylinders L 3.2L SFI SOHC | AutoZone.com
I would like to buy the first one cause it's so much cheaper.
Do you guys changing the sensor would be my best bet or should I check something else first?
Thanks
