Originally Posted by MRMARC
Added fluid and it still squeals. Now I see that its not good to mix the fluids. So I'm assuming the dealer can drain it and fill it with the right fluid?
you may have air in the power steering system as well since it was low...and you didn't listen to Steve and I to use the recommended oil....it may have to be bled out...look for any of the power steering lines that may be leaking, or the cap, or reservoir....good luck...
