Old May 16, 2011 | 01:53 PM
Erichenderson02's Avatar
Erichenderson02
Default Re: headlight adjustment
Originally Posted by gtrguy
What is the easiest way to aim headlights. I found the large white-capped horizontal adjustment screw, but where is the the vertical adjustment located. I have looked for the leveling bubbles but cant find them.
Any help would be appreciated.
Thanks
Yeah just make sure the bulb is seated properly. If you look at the base of the bulb there should be a small square tab that sticks up. Make sure that lines up with the tab in your headlight housing and then make sure the "speed" clip is attached properly.
-Eric
