Old May 16, 2011 | 02:29 PM
onehundred80
Default Re: headlight adjustment
Originally Posted by Erichenderson02
Yeah just make sure the bulb is seated properly. If you look at the base of the bulb there should be a small square tab that sticks up. Make sure that lines up with the tab in your headlight housing and then make sure the "speed" clip is attached properly.
-Eric
If memory serves me correctly, the tab is down on the low beams and up on the high beams.
