Old May 17, 2011 | 02:42 PM
onehundred80
Default Re: 74mm throttle body and larger MAF units on eBay
Thanks 180. I was thinking I might swap it out with my older one and see what happens
To remove the MAF sensor you need a tamper resistant five point Torx bit, not six point like the regular Torx, it is a pain to find. Beaner used a regular flat screwdriver and I used a tamper resistant flat screwdriver that fit like a glove. They are a bit tight but have a quick spiral thread.
I am not sure if the OEM sensor should be used, the car runs well though.
