I guess changing the gas cap is my next step. I found this on amazon (
Amazon.com: Stant 10843 Fuel Cap: Automotive ) Does anyone knows if I got the correct one? Thanks.
Originally Posted by rongarant
I had the same thing happen the other day. I still had half a tank of gas but I filled it up and the blinking light went out and hasn't came back on.
Same thing happened on me. First the blinking light once a few weeks, then once a few days, then the P0455 code. Now both blinking light and P0455(after I reset) came on everyday.
The main cause is usually the gas cap, loose or faulty. The second most thing I have found are vacuum lines split open at fittings, Tees, etc... James
Where are the vacuum lines located? or do I just inspect all the black rubber hose under the hood?
Originally Posted by robby363
When you fill the tank do you stop when the pump clicks off or do you try to squeeze more in to round it off to an even dollar amount? If you do that it can cause the fuel light to blink. Over filling it can cause fuel to get in the evaporative emissions system. I found this out when I first bought my car. If I squeezed in a little more after the pump first stopped. The light would come on after it got to about a 1/2 tank. It hasn't blinked sense I stopped trying to squeeze a little more in.
No, I stop at the clicks, although I might have did it a long time ago.
