Old May 20, 2011 | 02:38 PM
onehundred80
Default Re: Which fuse is the fuel pump fuse?
Originally Posted by Jesticle
I'm about to replace the fuel pump on my 05 coupe, and the repair manual says to pull the fuel pump fuse beside the relay control module. It doesn't say which fuse, and none of the 6 fuses are labeled.
any ideas?
The only marks say F1, F2, F3, F4 etc...
The fuse is in the Relay Control Module. The first 15amp fuse from the right (#4), check to make sure though.
