Old May 20, 2011 | 06:26 PM
onehundred80
Default Re: Odd new behavior
Originally Posted by AlG
I had something like that the other week. Turned out to be...and I kid you not...that the engine cover and its air tubes were not on tight thus creating a vacuum leak. Car had just been serviced at the dealer and the tech didn't make sure the cover was all the way down. I would check that and make sure all hoses are connected correctly.
I have had my engine cover not pushed down and I never had any trouble at all, I just noticed it a few days after I got the car. The car would be using some non filtered air at a very slightly higher pressure that's all.
I really cannot see why that would make much difference, and when you say vacuum leak it makes less sense to me.
I should add that Boilers problem would make sense as his car would be using unmetered air.
