Thread: Jacking Point
Old May 25, 2011 | 06:31 PM
James1549
Default Re: Jacking Point
I'm thinking he wants to jack up both rears at the same time to rotate his nondirectional tires from side to side.
Originally Posted by oledoc2u
not sure what you are asking....if asking where you can lift the car....it has jack points in the front just to the rear of the front tire under the rocker, and the rear point is just in front of the rear tire under the rocker...as pointed out, the car is so rigid, you can place the jack at the front point, and lift the front and rear at the same time...hopes this helps, sorry if I misunderstood...
