Thread: Closing Door?
Old Sep 14, 2005 | 03:41 PM
former NXMX5's Avatar
former NXMX5
Default Re: Closing Door?
there was a TSB out for this IIRC... i manually adjusted my window track because i had similar problems shutting the door, but mine was the drivers door. if you remove the rubber grommets from the bottom of the door, you should be able to adjust the window track. i ended up removing the door panel for mine.
good luck --
