Old May 29, 2011 | 10:46 AM
onehundred80
Default Re: What will it take?
Lol I have Rudy's number, but I'm not interested in a V8. I'm not far from my goal, even though every additional mph will require more horsepower. If it's not attainable though with the SRT motor I'll be very sad. :-( I don't want to molest my car with a turbo setup.
I'm thinking about C3 and mani's and exhaust. Plus retune ;-)
Time frame would be fall of 2012. After all I've got to get it done before the end of the world.
Parts needed would be in this order,
Oil sending unit **mine is leaking :-(
Koni shocks
Oil catch can
Tighed1's super cooler ;-)
C3 pulley or 178
Full Exhaust
Retune
Try to run to 180 (probably post spring 2012 Dragon)
If I fail,
Tweaked stock intake manifolds (thermal coated of course)
Retune and try again
Hopefully I want need the adjustable fuel kit
Good luck, you say you are not far from your goal but 10-15mph is a loooooong way to go.
To minimize the HP increase required you need to lighten the car and dump every possible ounce and that includes going on a diet. ( )
The front of the car needs to be smoothed out as well. Get good tires, check for loose bolts and check your insurance.
Don't do this at home folks, try Bonneville.
