Old May 29, 2011 | 11:26 AM
atlsrt44's Avatar
atlsrt44
Default Re: Hobbs switch and auxiliary fuel injector.
Ive seen something similar with the srt4. a buddy of mine that was running a hahn racecraft 20g setup was using something similar called a port fuelerHahn Racecraft - Automotive Turbosystems
if I remember correctly the extra injectors only kicked on after about 15psi when the fuel was needed.
If what you are looking at is similar Id say go for it unless your fuel pump is already maxed out.
