Originally Posted by Erichenderson02
Wow, what a great response.
Thanks for all of the information. I really want to spray my tail lights instead of tinting them because I think it looks a lot better.. but I was always worried about how to change them back to stock without having to buy a whole new set (~$450?).
I have a friend that sanded their tail lights with 2000 grit wet sand paper and then washed the lenses beforehand, is this the kind of prep you did?
Also, what kind of rubbing compound did you use to get the paint off?
Thanks,
Eric Henderson
Yes just use gloss black paint and gloss clear paint to do the job. When you want to remove it just sand it off using course / med / light wet sanding paper then finish with a rubbing compound from the local auto parts store. I used 3M compound then gloss clear painted them. Good luck and go easy with the black paint.
