Old May 30, 2011 | 11:28 AM
32krazy!'s Avatar
32krazy!
Default Re: SRT6 Cooling System Capacity
either way you need 2 gals. m/b coolant which is undiluted. mix 50/50 with distilled water and you have 16 qts enough for the entire job. i have done the flush on 2 cars and use approx 15 qts both times. but i also did a supercooler upgrade and tstat replacement so i was dumping fluid from everywere
easy job a 3 on a scale of 10
