Old Jun 3, 2011 | 01:06 PM
onehundred80
Default Re: Finish off that MB air box - ebay
Originally Posted by dtinker
onehundred80;
Thanks for the P/Ns. You mention modifying the pass through point of the air tubes by the radiator. do you have to cut these and/or remove the fitting that is on each side. Looks like you would need to do some cutting? what do you reccommend?
No cutting for me, I removed those plastic fittings and I will get the intakes through. The passenger side is OK for size but the driver side is too small.
