Old Jun 4, 2011 | 07:14 PM
ChuckNorris's Avatar
ChuckNorris
Default Re: transmission problems?
You have to drain the fluid, drop the pan, remove the electrical connector, and remove the valve body. The conductor plate is on top of the valve body. If you are not a seasoned mechanic you should take it and have it done by someone who will give a warranty. The car won't come out of limp mode until you fix the problem and have the code cleared.
