Old Jun 5, 2011 | 06:49 AM
cassidyrj1's Avatar
cassidyrj1
Default Re: master cylinder?
If you are talking about the car actually cutting power when you apply the brakes then it make since. Our cars have a brake master cylinder pressure sensor, I'm guessing there is a set pressure at which the brakes should reach when they are applied. On your car if the master cylinder cups are bad it will make it so the pressure can not be built up enough which then the car figures it will cut power to help you slow down.
