Originally Posted by oledoc2u
Can't see the photos as I am at work, but I believe you copied the design, and there isn't anything wrong with that if you are using better material than what the ebay store is selling. I the know for a fact the cost of material would be up there, and your time putting it all together. I wouldn't buy a system from ebay, or anything from ebay for that matter....I will take a look at what you are doing when I get home from work, as I am going to delete the resonators on both cars during my LSD install...would be nice to just to bolt something up, but, keep in mind, I have the same access to materials and can weld...so, may not be the best cost wise for me...but we shall see...
Yes I mocked my design after another muffler...and have not denied it at all but my dimensions are completely different and material is not cheap...and if you are able to weld and get some materials I would suggest going a dual exhaust route as the x pipe I made is a one off sound and had a really good tone to it. I will get some sound clips when my xpipe returns from polish...Sounds much better than the straight pipe I had on it! There are no performance gains between the two that I can feel but the sound is worth all the time in the world to build. I can send you my dimensions and what I used to complete the build...it took me almost a 3 weeks to complete the x pipe and muffler set up but I believe that I might be the only guy with a true dual...so let me know if you would like to talk about it...
