Old Jun 5, 2011 | 03:32 PM
onehundred80
Default Re: master cylinder?
Originally Posted by nidaysrt
Powering down, without changing throttle position and not braking, rpm's drop to about idle then back to original in seconds. The tech said the bypass was causing brakes to be applied, and the master cylinder was at fault. If its sounds right we'll fix it, I just don't want to start replacing parts to isolate the problem,
Thx
Frankly that explanation does not sound plausible to me. Why would the brakes be applied for no reason? I can hear the brakes when they are rubbing against the rotors, can you hear them when the revs drop?
