Old Jun 6, 2011 | 04:57 PM
  #81 (permalink)
chasw1970's Avatar
chasw1970
Default Re: Roadster rear window problem solved?
Originally Posted by mach2plus
Thanks for your write up and the fact that it is still holding up after 1.5 years. Given your info I did a lot of research and 3M, the manufacturer of the product that you used, 3M windo-weld 08609, recommends that you first use a primer on the glass prior to the windo-weld application. The recommended primer is 3M One step primer 08681.
Now, this all is beginning to make some sense, because when my rear window popped out i noted that none of the adhesive remained stuck to the canvas top, but that all of the adhesive was stuck to the window. Closer examination showed that the adhesive was actually stuck to what appeared to be a thin grayish black tape about 1/2 inch wide around the entire window edge. when i took a razor to it all that tape was a freakin bear to remove, while the adhesive on top of it came off much easier. After doing more research, I am absolutely convinced that what i originally thought was tape is actually a dabbing of glass primer put on prior to the adhesive at the factory. A quick look at the 3m website primer chemical composition sheet pretty much confirmed this, as once the primer MEK evaporates, it will leave a compound stuck to the glass that will look like thin tape, and promote the adhesive sticking to the glass. Maybe other forum members might confirm this?
Now, the million $$ question: Did you use any primer prior to using the 3M windo-weld?
BTW, the 3M Single Step Primer costs about $30, too include shipping.
Thanks again -- Bob
BTW, according to the upholsterer I took mine to for the original fix, it's a German made top. Incidently, the upholsterer's attempt at a fix lasted about a week and a half. I used tighed1's fix & it has held up pretty good. I have had to fix 1 particular spot a couple of times, but the rest has held very good since using the 3M.
It seems like the problem is more prevelent when I leave the top down for extended periods of time. I'm not sure if the weight from the frame that sits on it (in the down position) is putting pressure on it or what, but it seems to hold up better when I put the top up between uses.
