Old Jun 7, 2011 | 12:12 PM
  #95 (permalink)
freakingfastsrt6's Avatar
freakingfastsrt6
Default Re: Centric drilled and slotted rotors complete with posi quiet brake pad set for sale
driver side mounted
passenger side mounted
Now in terms of the way they should be mounted would be the way the vein direction is....in the case of the crossfire N/a there is not a directional vein. So really is up to you the way you want to mount the rotors....But make sure left and right side are going in the same direction, meaning the front left and the rear left side brake rotor should be mounted in the same direction not opposing each other. Which way is up to you. Reason being is the Rotors the N/a crossfire has are straight veined. On the srt6 is a different story as the veins are directional.
the rotors on the left are passenger side rotors and the ones on the right are drivers side. Again its up to you in terms of direction but this is the way I mount them. Also my vette rotors are directional and thats how they are meant to go...
hope this helps
