Old Jun 7, 2011 | 10:27 PM
James1549
Default Re: Roadster Top Operation
Originally Posted by BRappaport
Question: Do most roadster owners raise and lower there top with the engine running, or is it acceptable to operate the top totally off the battery?
Thanks
First off, I don't own a roadster but this is my opinion and others can chime in that may have an electrical backround. I don't see it a problem operating the top either way. My preference would be to use the top with the engine running (alternator charging). That way you are running the pump motor at a higher voltage (maybe 2 volts more) causing less amperage to operate the motor, and less wear and tear on the motor.
If I am wrong, please someone correct me.
James
