Re: I'm thinking Limp Mode...
That sucks Modless. Hopefully u get that figured out soon maybe it is the IC pump.
I do have the Johnson CM30 Pump. Retarded if its already bad.
Anyways, DJ, I took ur advice and ran the car all day today everything was fine. Then, it happened about 2 hours later. Turned it off and back on everything was fine.
Now this is odd to me and maybe someone can chime in. My odometer is bright green right now i think brighter then normal. When the car loses power my odometer #'s gets all choppy and disfigured then the car loses power. When its back to normal the car is fine. Could it be the battery?
Im going to go with a bosh pump and swap it out and see if it works since its the cheapest to do. I really hope its just the IC pump on the verge of failure and thats it.
Can u access the pump without taking the bumper off?
