Old Jun 9, 2011 | 08:11 AM
ModlessG's Avatar
ModlessG
Default Power loss different that the ic pump
The car is at the dealer so I am trying to get information so I can tell them what I think its doing. Several weeks ago the car went into what I believe is limp mode.It will hardly get rolling from a stop much less power than what I experienced with the bad ic pump.It did not throw a code or any check engine light the first time.I turned the car off and restarted a few minutes later and it was fine. Then on Monday this week it repeated same thing except it now had the check engine light on. Tuesday it went to the dealer. They said it was the transmission causing the check engine light.It was low on fluid because of a leak. So they do the repair. I drive about 3 miles and it goes into limp mode again. I take it right back to the dealer. I get a call back that they cannot get it to duplicate this problem.It seams to only do this when the car is fully warmed up, and driving in traffic as I get caught not being able to get off a light.What else should I be looking for?? thanks
