Old Jun 9, 2011 | 09:30 AM
BoilerUpXFire
Default Re: More "Things I didn't know about my XFire"
Originally Posted by Joliet John
#2 - If you want to sit in the car for a few minutes after you turn it off, and it's cold outside - if you hit the recirc button, the fan will come on and continue to blow hot air for a little while.
Agee... I also try to pretend I don't have a cup holder. the heat feature worked great in the wonter time. I turn in go into a restraunt and the car is still comfortable when I get back in.
As stated, this works in regards to the AC as well, after all, this time of year, NO ONE should be using their heat....
Another nice thing, when you hit the recirc after using the air conditioning, it allows all the moisture to be purged from the system so you have no foul smells next time you turn it on.
