Originally Posted by freakingfastsrt6
285 30 19 is the widest you'd want to go....if you had 19.5 width wheel rear that would be no problem to fit a 295 30 19...but To be safe use a 285
295 is only 10 mm wider than 285. That's only 5 mm or .20" wider per side. If 285 is ok and 295 is not, how is .2" gonna make a difference ?? That's less than a quarter of an inch per side??
