Originally Posted by MikeR
Doc, I just found that out a couple of weeks ago with the Intrepid.... it didnt want to start on two attempts and then did but gave a CEL..... was for camshaft position sensor... I replaced it and all was well and the car is running better now... on investigation I found that the Intrepid uses a crankshaft position and camshaft position sensor just like the Crossfire..... At least they are easy to fix!!
What are the symptoms for a bad camshaft sensor?
I've had a code for the camshaft sensor(not crankshaft)for like 4 weeks, but car was running fine. Now the last few days 1 out of 8 starts it has problems starting and today it died while waiting in line at taco bell. I disconnected the battery and connected it again and then it started.
What I'm wondering is, is it unrelated, may be a bad battery or other problem, or would a bad sensor cause this?
