Old Jun 14, 2011 | 12:41 AM
  #50 (permalink)
FTroopChief's Avatar
FTroopChief
Default Re: All white with an underbite...
I have been going All-White for about 2 years, as the piggy bank would cough up the working capital.
Magnaflo 16633 installed.
1st items were custom grille and lower units. Steel mesh with 1/2 inch strap on upper and 3/8 inch rod for lower perimeters.
Diffusers were added and pearled with the car.
Body was prepped for Shimrin P-44 "Snow White Pearl and 2 coats of Clear.
Windshield surround was also painted and custom CROSSFIRE letters applied to to of surround instead of windshield. Charcoal w/silver metal flake.
Engine cover was modified removing KN Filters and smoothing inside of air filter housings. 1/2 inch window weather stripping filled the perimeter of the air boxes and black silicone created air tight seal, torx screws were locked down tight without stripping.
Air Brush artist Can2 of San Antonio painted the engine cover with theme picture "Snow White" I supplied, did subtle striping and painted the Crossfire letters.
Flexible "Snorkels" were removed and Spectre replaced them. Cone filters are mounted INSIDE the engine compartment and offset to the side of the radiator and fan. Flex tube is run through the enlarged original Snorkle mounts and chrome tubes mounted both inside the grille area and the engine compartment ducting fresh outside air to the Cone Filters.
Swapped my Magnus Millenium wheels with my SRT6 and had the SRT6 wheels prepped, powder coated and primed. Rubber is General Ecclaim UHP. Front- 255/35/18/8.5...Rear 275/30/19/9.5.
One more exterior mod to go.
not telling 'till done.
pics to follow
Last edited by FTroopChief; Jun 17, 2011 at 06:29 PM. Reason: add pics and change post date to 6-18-2011
