Old Jun 17, 2011 | 08:04 PM
Dementors's Avatar
Dementors
Default Re: What the heck did I do here ??? Comments please
Woody,
Sub 2 second 60' times are good and mph should be higher. Also, did you run these passes close together? I ask since the pass times slowed up. I normally see my times slow up as the night goes on unless I allow the motor to cool usually 45 min between passes. fyi...I am running 255 PS2's in the rear with stock suspension.
I will break traction when reving to 1500 rpm's sometimes as well but the car does not push through the light. Maybe you did due to the slicks??? Track prep is also important and could have been a factor. Track condition is normally better earlier in the night before many passes have been done.
My best run is as follows:
2.001 60 ft.
8.126 1/8th - 89.40 mph
12.46 1/4 - 113.09 mph
