Yes it is.
I really fail to see why both parts would fail at the same time. I would suspect the multi function switch first if the fuses were OK.
These components can be checked out using the diagnoses outlined in the repair manual available here. It is not restricted to SRT6 info as the title implies.
https://www.crossfireforum.org/forum...tml#post111722
None of those links work once you click on your original link..
