Old Jun 27, 2011 | 11:14 AM
bmorgan's Avatar
bmorgan
Default Re: Alarm going off on its own! interior light flickers / unlocking randomly if driving!!
The fuse is located under the hood on the drivers side. It should be fuse number 9. The SKREEM is in the dash.
Here are some potential things that can cause your alarm to go off on its own:
FALSE GLOVE BOX SWITCH SIGNAL
FALSE LIFTGATE LOCK SWITCH SIGNAL
FALSE HOOD AJAR SWITCH SIGNAL
FALSE LEFT DOOR AJAR SWITCH SIGNAL
FALSE RIGHT DOOR AJAR SWITCH SIGNAL
FALSE IGNITION SWITCH SIGNAL
FALSE BRAKE LAMP SWITCH SIGNAL
FALSE ANTI-THEFT TOW SENSOR SIGNAL
INTERMITTENT CONDITION
I believe the item in the trunk he was referring to is the central locking pump (He can clarify if he was referring to something else).
You may need to take it to a shop and have them use the DRBIII to isolate the condition that is triggering this.
If you have not already done so, go here https://www.crossfireforum.org/forum...ollection.html and download the SRT-6 Service Manual. It will give you loads of information to diagnose your condition.
I hope this helps, and good luck with getting it resolved.
