Old Jun 27, 2011 | 10:39 PM
James1549
Default Re: Washer Fluid Jets Not Working
I am not sure what "tweaking" the brakes involves, I would be curious to know.
As far as the washers, can you hear the pump run when you try them? Have someone stand by the passenger fender while you try it and listen. If you can hear the pump run, maybe the nozzles are clogged. If it isn't running, maybe a bad pump, switch, or connection.
Good Luck. James
